Is there a way to backtrack in the web app without using the browser ‘back’ button? Or the conttext menu ‘back’ option?
All the shortcuts on my laptop/browser seem to work except the ones for ‘back’, i.e. ‘alt-left arrow’; or ‘backspace’ / ‘shift-backspace’.
Thank you,
Jim Julian
In the upper right hand corner click the down arrow
Select keyboard shortcuts
I don’t think there’s a dedicated back button but there might be something in there that works
If you are using Chrome, you can install this extension by Google from the web store.
Go Back With Backspace - Chrome Web Store That will restore the ability to go back in most cases using the backspace.
If using Firefox, you can follow the steps here: How to restore backspace button function? | Firefox Support Forum | Mozilla Support
Edge (chromium based) should allow you to install the extension from the first link.
For any other browser, I’m not sure as those are the main 3 I use.
-Shark2k
Huh. You know, I was just using my browser to set up a music playlist, and I wondered what happened to the back button in the UI. I suppose that since browsers have a back button already, I guess they felt there wasn’t a need for one in the browser player.
I could’ve sworn there used to be one in the browser, but since I use the Plex-for-Windows app most of the time, maybe I was just thinking of that app? Would it hurt to include it in the browser app, for consistency’s sake?
Just read your response.
Thanks to shark2k.
