Missing and Incorrect EPG Switzerland Swisscom Blue
Missing channels
BBC Three HD
FIlm 4
5 Select
CNBC UK
Blue Zoom D
Lineup: Swisscom Blue TV (Deutschschweiz)
Country: Switzerland
Postal code: 3436
Plex version: 1.42.1.10060
Wrong language for EPG data. French instead of expected German.
Arte HD
Postal code: 3436
For the missing channels Gracenote had slightly different channel names so I think they wanted to confirm if they are the right ones.
  • BBC Three HD (122089)
  • Film4 HD (68051)
  • 5SELECT (56888)
  • CNBC (68892)
  • blue ZOOM HD (109984)
( the numbers in parenthesis are channel ID numbers.)
Thanks for following up. The channel names look fine to me. But please see my remarks below.
  • Film4 HD (68051)
    Only the SD version of Film4 is currently available though Swisscom BlueTV
  • CNBC (68892)
    This channels is broadcasting in HD, however
In both cases, the listings should probably work anyway. It’d just provide inaccurate HD-tags in the guide, I suppose.
    Similar to the channel ARTE HD mentioned above, there is a German and French version of this channel. The expected EPG language for this list would be German.
Is there a way to specifically check the channel id numbers?
not that I am aware of. They are internal to Gracenote i just did not remove them when i copy pasted it from them
