Missing art work
Most of the art work is missing. This happened after the last update. Current version is 4.71.0
Same thing is happening on my install, though it is sporadic depending on client (mostly Nvidia Shield, FireTV & AppleTV). Seems like Shield is the worst. Covers not showing there, do show on Apple?! Did you resolve your issue? Thx
I’m not sure why but I set up a daily auto restart on my server and that seemed to fix the problem. It’s running on an old HP ProDesk slim with Windows 10 and a 1030 card. The card costs more than the PC… LoL :laughing:
:joy: Thanks. Did u set up the restart in Windows or Plex?
I set it up for windows
