Missing DVR settings and cannot record
First time post so be gentle please. Problems today with plex server seeing my tuner card - live TV option was missing. Moved card in machine and resolved that issue, re-added DVR, scanned channels and things looked good but no DVR settings or record option on shows. Windows 10 20H2. Any thoughts or ideas welcome, thanks! Gonna try and figure how to upload log files I saved.
Server Version#: 1.23.5.4862
Tuner Make/Model: Hauppauge wintv-hvr-2250
Guide/Lineup name: All
Using XMLTV?: No
Channel number/Name: All
BTW, just tried removing TV.* files in \appdata\local\Plex Media Server\Plug-in Support\Databases, removed DVR, then restarted. Tried to re-add DVR and plex could not see it again. Removed device manager entry (uninstalled), restarted and it returned. Back in the same boat now. Log files attached
(upload://rh8OqyXQFPekvvYntxKie8eCThi.zip) (4.5 MB)
Crazy ■■■■. After removing all the TV DB files, re-adding the DVR and channels - I did not have a guide or channels to view so I stopped services, put the TV DB files back, restarted services and plex server - EVERYTHING appears resolved. THis includes record and DVR setting option. Will mark this resolved soon - hope it helps others.
