Missing icon for movies @ shows, LiveTV, Webshows
Hello, I have 3 Plex Linux Server and 3 Windows apps.
Only one shows set shows no icons but my library’s Icons are OK. I reinstall the windows app., but not still the same. Please help.
Thanks,
-Dieter
I’m not sure I understand your issue.
Would you mind throwing it into Google translate to get a better translation? Alternatively you can try phrasing it in your native language and moving the post into that section.
Hi Tom,
Thanks for your reply. I was not able to show the icons. I ended up restoring a 4 week old windows backup and the problem disappeared.
Thank you for your help.
-Dieter
