Missing Media
Hi, Hoping that someone can help, I have a TV show (well one episode\special) that isn’t showing up in my media library. As far as I know, my libraries are set up OK I have other media that works fine :slight_smile: my library is set up as
\TV\The Farthest\The Farthest.MKV.
The show on IMDB is here - also “The Farthest” where am I going wrong?
https://www.thetvdb.com/?tab=series&id=334154&lid=7
TIA
SF
That filename will not work. Since this is a TV series, you need to use the season/episode naming guide. Try the following instead.
\TV\The Farthest\The Farthest S00E01.MKV.
Your format should be
\TV\The Farthest\Special Content\The Farthest - S00E01 - Voyager in Space.mkv
\TV\The Farthest\Special Content\The Farthest - S00E02 - Second Genesis.mkv
It seems there are no seasons for this in the TVDB but two episodes in specials.
For Plex the Specials must be season 0.
Try that naming.
Good Point - thank you - I guess as I thought it was special - I forgot about the episode numbering - will confirm in a moment!
Thanks @“MovieFan.Plex” That worked - all shows up now!
Thaks for the answer too @jjrjr1 that seemed to work :slight_smile:
