Show not recognised
Server Version# 1.105.1.257
Player Version# 1.41.2.9200
<I have the following configuration on my system
Although the rest of the shows is properly appearing in the library, the highlighted one doesn’t (“Plex Series” is used as an agent for this library)
I tried following both tvdb and tmbd namings but still no result.
The folder contains all 44 episodes of the show in AVI format, playable in VLC
I also tried to covert some AVI files to MKV format but sill, no result
Any ideas as to what am I doing wrong?>
Perform the Plex dance after correcting the file names and the folder structure.
Yes, you need a Season folder even if this show only has one season.
Ensure that the Plex series library has been pointed to L:\TV Shows and nowhere else.
I see there is a single episode in there that is not inside a folder. Don’t do that.
The folder structure is very important for recognizing your files.
Thanks for the tips
