Missing Movie Library Recommendations (Merge Recently Added Items selected)
Right, so then it’s just ‘recently added’ that seems to be bugged. (on my computer anyways)
But you told Plex to merge all “Recently added” hubs.
So you will see only one Recently added Movies hub. And only then if the participating libraries actually had new items added in recent weeks.
That is correct, and it isn’t working
Recently added TV and recently added Videos work fine
And all those libraries have already been converted, including “Refresh Metadata”?
Are all of them pinned to the left side bar?
Yes all have been converted, and all are pinned
Please activate logging,
then recreate the issue
We need both server log files.
and logs from the used Plex client. Plex Web App Logs | Plex Support
Both logs taken at the same time.
Sure.
What do you mean by re-create the issue? The issue never left lol
Just navigate away and return to the Home page a few times. :slight_smile:
Zipped into 1 file and had to Dropbox it because one was too big to upload here
Maybe I should just try repairing my database anyways?
You can try. If you do it right, it can’t hurt.
How do I do it right?
Exactly like this: Repair a Corrupted Database | Plex Support
It didnt change anything. Thanks anyways tho!
There is currently no season – hence no hub.
When does the Christmas season start? My family has already started watching Christmas movies (Yes I know it’s way too early but whatever) and it seems dumb that I can’t just enable or disable the seasonal movie and select what season
