I have (5) Seasons of TV show “Martin”
All seasons used to show then one day I was missing files (movies/TV shows) on the desktop itself (Internal SSD was running out of space, but never heard of Windows just removing files)
I keep an external hard drive with all my content backed up so it was easy to replace the missing files and now I just leave the external drive connected and have linked to PLEX Server as the source for all movies and TV Shows.
Now all of my content shows up as it should EXCEPT Season 01, 02 & 03 of “Martin”
Season 04 & 05 show just fine with all episodes.
Everything is named accordingly as it once worked with same naming convention.
What can I try here?
Any guidance would be greatly appreciated.
“Same” doesn’t matter. It must be the “right” naming convention. https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
How are your files named?
How does the folder structure look like?
Which folder level has been added to your tv show library in Plex?
Are these files in mp4 or m4v format?
Season 04 and 05 show up fine
Season 01, 02 and 03 DO NOT
I do not want to imply that “same” is “right”. Just pointing out that this same naming convention once worked and all seasons showed up nothing was changed aside from the location of the files.
What am I missing?
Let me know if you need more references. Thank you for responding.
I don’t see any file name extensions. Are you using mp4 / m4v files?
Have you checked that in the properties of your tv show library, on the “Add Folders” tab, only the folder ALL VIDEO HUB is appearing?
Yes, that is wrong.
You add only the folder ALL VIDEO HUB to the library.
If you also store videos of the type “Movie” underneath ALL VIDEO HUB, you must create a folder beside ALL VIDEO HUB and move all TV Show content into it.
Crazy how all the other content shows just fine just not these 3 folders but I tried it the way you told me to, and VOILA!
Thank you so much Otto!
