MKV file being seen as audio book
Adding the star wars collection to my library. All came through fine except for the force awakens. it’s being seen as an audio book in plex. I renamed according to plex guidelines as well as used filebot after to rename as well. I have added three different times and it’s still pulling as audio book. Has anyone run into this before?
Go to the Local Web UI or Plex.tv Web UI
Locate the item in the Library.
Click on the THREE DOTS (ignore the pencil (1)) I goofed.
Select 2, Fix Match (2) OR
Select 3. Unmatch (3)
Fix Match will bring up suggested media titles and you can also search manually for the proper matching metadata.
Unmatch is to dissociate the current used metadata entirely, and rely only on the original title from the file
Thank you I didn’t even think of that. I feel stupid but it’s in there now. Cheers!!!
