The Image below is how Plex imported these MP3s.
Below is an image of how the file metadata is formatted.
Wha?!?!
Plex didn’t use your local metadata.
considering you’re not following any particular naming convention proposed by Plex, it apparently mismatched the audio book with the 2nd part of the same audio book.
your options are:
All you said, basically, is that I’m doing it wrong and need to it right…Thx for not being helpful.
You’re putting it very hard… but yes, that’s basically the message if I tell you how to fix it
I helped by pointing out how to fix it… if you choose to ignore it because you feel it’s no solution for you, my solution was indeed not helpful (to you)
