More Balanced View of "related" tracks section on Plexamp Now Playing Screen
I want to suggest a more balanced view between sonically similar tracks and lastfm powered related tracks suggestions. Currently, you only get one sonically similar tracks suggestions and a bunch of “other” related tracks. I would rather have a balanced view of equal suggestions or even more sonically suggested tracks. See image below for the current view.
The fact that you only see 1 sonically similar track is down to the fact that your library has only this one track in it that is similar enough. If you had more, there would be more listed.
Thanks for the speedy response @OttoKerner however I don’t think so. If you expand the view by right clicking and selecting related tracks, you get a much wider selection. See below:
Regardless of the matches. You always get a single suggestion off the main screen.
You are right, indeed.
Sorry for my hasty response!
No worries. One of my favorite things to do with Plexamp is to do a Deep Cuts with a DJ Stretch. I use sonic suggestions to disrupt the mood of the music playing and use that section a lot. Would rather get more sonically similar matches than arbitrary relates tracks based on lastfm suggestions or whatever source is driving the other section.
