"More Info" does not list multiple copies' track info correctly
Server Version#: 1.41.6.9685
Player Version#: Has been going on for some time.
If you have multiple copies of a movie, the app is not listing the track info of all copies accurately. This has been an issue for years now, and yes, I know you are working on a new app. Would be nice not to have this problem get carried over to it.
Steps to reproduce:
  1. Put two copies of a movie into the same library so they both match and are listed as a title with multiple versions. Use a different resolution or video codec or different audio formats, etc.
  2. Go to the pre-play screen for the movie and go to the overflow (three dots) menu. Choose “More info” from there.
  3. Review the listed track info for both files.
Expected behavior: Each copy of the movie will be listed with its unique track details on the info screen.
Actual behavior: The screen lists the correct file names of the two files, but the details for the second copy of the movie will just be a repeat of what the first file’s info was, not correct info for the second file.
Is this specific to the Android TV app?
i.e. does the web app show the correct info?
Hosted web app and Plex PC app are both showing the correct info for the alternate versions.
Only an issue on Android TV/FireOS. Haven’t had the chance to check a Roku, if it has the More Info screen. I realized just now PlexHTPC doesn’t have that option.
