Movies and duplicates // mod: indicator for multiple versions on big-screen apps
When you select a movie you see a lot of info on the screen which I like. But it does not clue you in if there is more then one copy of the movie in your library. You have to go to the 3 dots (more). Can we get a simple indicator on the info screen if more than one version exists in the library?
If there’s multiple versions, those should already be listed on a movie’s main page.
Mine does not look like that. My client is the Shield Pro.
I was referring to Plex Web.
On the big-screen apps, you can indeed only see if a movie has multiple versions if you check for the availability of Play Version from the context menu (...). Alternatively you can filter your library by Duplicates… but that’s not like showing a status indicator on the details page.
It would be more user friendly if one could see (and chose for playback ) if there are multiple versions (files) of a movie in a prominent spot (like the movie info page). Currently the only way to see this is hidden inside the … dot menu on the movie info page.
