More Playlist in one view than another
Server Version#: 1.31.2.6810
Player Version#: n/a
Hi. I’ve had this minor issue for years (possibly since I started using Plex 5ish years ago). If I navigate to Music > Playlists, I have 44 playlists. If I navigate to Playlists > Music, I have 20. All playlists are working and both lists contain a mix of regular playlists and smart playlists. Not a big deal but very confused why there is a divide here. Could not find anyone else with this issue so wondering if anyone else is experiencing or just me?
Do you happen to have more than one library of the type “music”?
I do have more than one “music type” library. However, all 44 playlists I have do show up when I go to the Music library > playlists. Only 20 of those show up when I use the Playlists section > Music tab. I should add that I long ago imported most of these playlists from my old itunes library, however of the 20 playlists that show up, some are and some are not from that old itunes import. There does not seem to be a pattern to the missing playlists.
