Most recent thumbnail not clickable, skips to 2nd episode
In TV Show episode view, sorted by ‘date added’ descending, the most recent episode is not selectable. Pre-select automatically jumps to second most recent episode. At the very same time the cast icons flicker/reload constantly.
Plex 7.29
TvOS 15.4 (19L5419e)
I’m getting the same thing on mine but I’m running on 7.28.1 and TvOS 15.4 (19L5419e)
On my other Apple TV’s I’m running 7.28.1 and release TvOS and they are fine.
I couldn’t think of a way to describe it.
Same issue started less than a month ago.
Tried 7.29 > 7.26 and it doesn’t help so I’m thinking this started with a server upgrade.
It only seems to happen when selecting the first episode of a series when hovering over the episode image. Automatically jumps to second episode.
On some shows the icons showing the details ie “1080p 5.1 AC3 (CC image) off” start twitching where the CC off symbol disappears then reappears constantly.
If you navigate down to the play button the first episode is highlighted but the second episode plays.
Also noticed for shows that have cast details where the cast list doesn’t fit on one screen the twitching/cycling corresponds to the cast list cycling between the first and second page of the cast members.
Very frustrating.
Tried different server versions, deleting app, different settings, etc.
Yup. Happening on the beta tvOS.
Same, here.
