Move multiple Items on Playlist
Hi there
There is a really central feature missing, which I cannot find anywhere and doesn’t get any attention: Moving multiple items in a playlist.
I googled for it for a while now and the only thing I can find on that topic is an unanswered reddit-post:
The problem:
Currently when I am trying to order my items in the playlist (especially when adding new items to the playlist, which will be on the buttom), my only two options are:
  • Move all tracks one by one to the wanted position (tidious and veeeeeeeeery annoying)
  • Delete all tracks in between and add them again afterwards (which is hellish as well)
So if I want, let’s say all the same artists after one another I am really struggling to get a playlist with which I am satisfied.
How I would imagine the solution:
When I have selected multiple items in my playlist I should be either able to simply drag&drop them to the wanted position or cut (ctrl+x) and paste (ctrl+v) them or have a move button with which I am able to enter the position to which the items should move.
Either of these ways are better than the current ones.
Thank you for implementing this feature in the future in advance :-).
Best regards
There is an existing request for this feature. Rather than splitting votes over several threads, it’s best to add your vote and comments there.
Thank you for your reply! I will do so.
