Moved Plex Media server to older version to keep system from crashing
Back to crashing. First, it cycles off and on. Then it goes goes down.
TPlex Media Server Logs_2024-12-06_03-43-11.zip (2.4 MB)
Plex Media Server Logs_2024-12-08_05-50-56.zip (3.1 MB)
There is one interesting thing I noticed in your logs from 12/6; there are warnings and errors concerned with testing access to the root of your C: drive:
Dec 06, 2024 03:42:30.645 [20908] ERROR - IsFileWritable: failed to create file '"c:\c5220125-3582-4e14-a585-24a703eba5c1"'
Dec 06, 2024 03:42:30.645 [20908] WARN - IsDirWritable: directory '"c:\"' is not writable
These are the logs which cover version 1.41.3.9276. However, these warning and errors are not present in the last set of logs which are all from version 1.41.2.9200.
I don’t know if it’s significant, but it is a difference. Do you have anything in your configuration which points to the root of your C: drive (C:)? It seems like this could be permissions-related. Perhaps the user you’re running under doesn’t have access to that path?
So you have issues:
Dec 08, 2024 05:27:09.653 [19952] WARN - [HttpClient/HCl#3] HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (7, Couldn't connect to server) (Failed to connect to plex.tv port 443 after 0 ms: Couldn't connect to server)
Dec 08, 2024 05:27:09.634 [19952] WARN - [HttpClient/HCl#2] HTTP error requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx (35, SSL connect error) (Recv failure: Connection was reset
Dec 08, 2024 05:27:10.479 [18276] DEBUG - NetworkInterface: ignoring adapter 'Local Area Connection' (fe80::a0f8:f2e5:9a4b:92ec%9,100.64.100.6) because it has no gateway
and you have a Hetzner IP address Not Allowed to use Hetzner
So good luck…
Uploading: Plex Media Server Databases_2024-12-08_06-16-34.zip…
What is Hetzner’s IP address and how do I change it to something acceptable?
That is not a Hetzner address.
That is the dedicated address block for CGNAT which many ISPs use. It will impede remote access, but not claiming of the server.
Plex Media Server Logs_2024-12-16_16-37-32.zip (1.4 MB)
I’m still having issues keeping the media server up. I moved back again to non-beta, but I’m not having any luck. Do you have any suggestions?
