Although I need all the metadata about the movie, how do I lock down my own covers? It’s the only thing I can’t seem to force Plex from changing. Is there a way to make it leave my movie covers alone and not replace them. I put a cover in each folder with the name exactly the same as the movie and containing folder.
Unfortunately, there is no way to instruct Plex to use them primarily - without also preferring embedded metadata.
(If you have .mp4/ .m4v files, these can contain embedded meta tags. They often contain wrong data, so the movie is displayed wrong within Plex or, worse, even gets recognised as a completely different movie.)
If you have no embedded metadata in your files or you can make sure they are all correct, do this:
Settings - Server - Agents - Movies - Plex Movie
drag the line ‘Local Media Assets’ to the topmost spot in the list
repeat the same under
Settings - Server - Agents - Movies - TheMovieDatabase
With a correctly named poster.jpg in place, perform the Plex Dance with one movie to see the effect of the change.
Funny you say that as a copy of the cover is also muxed into the MKV file of the movie too, as habitat I’ve always done this, chapters too via toolnix.
Plex doesn’t read metadata from mkv files.
Just from mp4 / m4v files.
If you only have mkv files, it is safe to make the above metioned adjustment.
(Although it is the default in Plex. If Plex didn’t pick up your posters vefore, they were either not named right. Or you only added the poster file after the movie has already been added into the library. That won’t work. The poster must be present from the start to get selected automatically.)
So I did a complete once over for all my collection making sure every title had the cover named correctly. I deleted the movies list, optimized data base, cleaned bundles, deleted old files. Rebooted. Added new library for movies. It only chose my cover occasionally and picked its own choice for the majority.
