I have the 2016 version of Ben Hur and for some reason the poster and description is for the 1959 version. I added the year in the name. I called it " Ben-Hur (2016)"
If this is a mp4/m4v file:
If it is, it could contain internal metadata which can potentially throw off Plex’s scanners.
To avoid troubles with embedded metadata, go to Settings - Server - Agents - Movies - Plex Movie
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Or fix the embedded ‘Title’ tag in your files, so it contains sensible data.
While you’re at it, perform the same adjustment under
Settings - Server - Agents - Movies - TheMovieDatabase
and
Settings - Server - Agents - Shows - TheTVDB
and
Settings - Server - Agents - Shows - TheMovieDatabase
Afterwards, perform the Plex Dance with the affected movie.
