Movies and TV feature
Server Version#: 1.18.2.2080
Player Version#: 1.4.1.940-574c2fa7
The new Movies and TV feature released on December the 4th shows up in my android app, but is missing from the windows 10 app.
I thought this might be to do with ‘online media sources’ in the account settings, but there is noting relevant in here either.
I have re-installed the plex desktop app to ensure I have the latest version, but this hasnt helped. Is anyone else also seeing this issue?
Thanks,
Andrew
In the web client settings on the left under account, select ‘Online Media Sources’
on the right you can enable/disable these items.
Thanks Dave…I only have web shows, news, podcasts and tidal listed in there. I have all enabled.
I dont think it can be my server settings, as I have it working on android off the same server.
I think there isnt enough room on the menu bar and it has been forced off the bottom…with the splitter and MORE> overlaying it.
Not all apps support this yet, to see a list of supported apps see here: https://support.plex.tv/articles/video-on-demand-overview/
Need to use https://app.plex.tv/web, Windows/Mac Apps not yet supported. Has to do with DRM.
Thanks guys…web app it is then.
Cheers,
Andrew
