This is one of the files in the scanner log. I only have 6 of this type and I’m missing way more than that.
Jul 11, 2018 09:41:59.630 [4204] INFO - Plex Media Scanner v1.13.2.5154-fd05be322 - Microsoft PC x64 - build: windows-i386 - GMT -06:00
Jul 11, 2018 09:41:59.630 [4204] INFO - Windows version: 6.2 (Build 9200), language en-US
Jul 11, 2018 09:41:59.630 [4204] INFO - 8 3392 MHz processor(s): Architecture=0, Level=6, Revision=10759 Processor Identifier=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
Jul 11, 2018 09:41:59.630 [4204] DEBUG - "C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe" --analyze --log-file-suffix " Analysis" --item 64781
Jul 11, 2018 09:41:59.505 [1084] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
Jul 11, 2018 09:41:59.677 [1084] DEBUG - Analyzing media parts for item 64781 (Episode 3): 109448
Jul 11, 2018 09:41:59.677 [1084] DEBUG - [ID 112818] Media part analysis: S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv
Jul 11, 2018 09:41:59.677 [1084] DEBUG - [MI] Opening input file: "S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv"
Jul 11, 2018 09:41:59.677 [1084] DEBUG - [FFMPEG] - Opening 'S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv' for reading
Jul 11, 2018 09:41:59.677 [1084] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Jul 11, 2018 09:41:59.771 [1084] WARN - [FFMPEG] - Format matroska,webm detected only with low score of 1, misdetection possible!
Jul 11, 2018 09:41:59.771 [1084] ERROR - [FFMPEG] - Read error at pos. 1 (0x1)
Jul 11, 2018 09:41:59.771 [1084] ERROR - [FFMPEG] - EBML header parsing failed
Jul 11, 2018 09:41:59.787 [1084] DEBUG - [FFMPEG] - Statistics: 1048576 bytes read, 0 seeks
Jul 11, 2018 09:41:59.787 [1084] ERROR - Exception analyzing media file 'S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv' (Could not parse S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv (error=-1094995529): Invalid data found when processing input)
Jul 11, 2018 09:41:59.787 [1084] DEBUG - Streams didn't change in analysis, not saving.
Jul 11, 2018 09:41:59.787 [1084] DEBUG - Updating media item 109448, size=882376704, metadata_item_id=64781
Jul 11, 2018 09:41:59.787 [1084] DEBUG - Updating part with ID=112818 [S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv]
Jul 11, 2018 09:41:59.814 [1084] DEBUG - [MI] Opening input file: "S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv"
Jul 11, 2018 09:41:59.814 [1084] DEBUG - [FFMPEG] - Opening 'S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv' for reading
Jul 11, 2018 09:41:59.814 [1084] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Jul 11, 2018 09:41:59.883 [1084] WARN - [FFMPEG] - Format matroska,webm detected only with low score of 1, misdetection possible!
Jul 11, 2018 09:41:59.883 [1084] ERROR - [FFMPEG] - Read error at pos. 1 (0x1)
Jul 11, 2018 09:41:59.883 [1084] ERROR - [FFMPEG] - EBML header parsing failed
Jul 11, 2018 09:41:59.883 [1084] DEBUG - [FFMPEG] - Statistics: 1048576 bytes read, 0 seeks
Jul 11, 2018 09:41:59.883 [1084] ERROR - Exception extracting thumbnail from media file 'S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv' (Could not parse S:\TV\Preacher.S03E03.720p.HDTV.x264-AVS[rarbg]\Preacher.S03E03.720p.HDTV.x264-AVS.mkv (error=-1094995529): Invalid data found when processing input)
Jul 11, 2018 09:41:59.883 [1084] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jul 11, 2018 09:41:59.883 [1084] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Jul 11, 2018 09:41:59.883 [1084] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Jul 11, 2018 09:41:59.883 [1084] DEBUG - Updating metadata item (save) () with ID 64781
Jul 11, 2018 09:41:59.883 [5320] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jul 11, 2018 09:41:59.898 [5320] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jul 11, 2018 09:41:59.914 [5320] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=4&metadataItemID=64781&metadataType=4&state=-1&mediaState=analyzing
Jul 11, 2018 09:41:59.930 [5320] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=4&metadataItemID=64781&metadataType=4&state=-1&mediaState=analyzing
Jul 11, 2018 09:41:59.930 [5320] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=4&metadataItemID=64781&metadataType=4&state=-1&mediaState=thumbnailing
Jul 11, 2018 09:41:59.930 [5320] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=4&metadataItemID=64781&metadataType=4&state=-1&mediaState=thumbnailing
Jul 11, 2018 09:41:59.930 [5320] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=4&metadataItemID=64781&metadataType=4&state=-1&mediaState=idle
Jul 11, 2018 09:41:59.945 [5320] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=4&metadataItemID=64781&metadataType=4&state=-1&mediaState=idle
