Movies metadata in wrong language (English instead of Japanese)
Server Version#: 1.18.6.2368
It used to work, but now it doesn’t anymore. I have a library with all my Anime movies. For that folder I have it set so that all metadata is in Japanese:
  • At the AGENTS level : set to Japanese
  • At the LIBRARY level : set to Japanese
    Yet when I now add a new anime movie, all metadata is set in English.
I have a Anime TV SERIES Library that works just fine, with the same settings.
The only difference that I can tell is that the folder that scrapes correct metadata is set to TVDB and the one that doesn’t work correctly is set to MOVIEDB. Even if I switch to PLEX MOVIE as the main agent, the problem remains.
The Plex dance also didn’t solve this issue.
Any idea what to do next?
