Multi-channel AAC codec Chromecast / Iphone
2.12.3
NEW:
Removed support for multi-channel AAC codec
FIXES:
Fixed issue where some videos would fail to resume and would play from the beginning
Fixed issue where casting videos would fail if subtitles were enabled
It does not seem right that in the last update remove this option as it was something that worked perfect.
I have all my movies with multichannel aac sound to avoid bugs in plex android etc. My server never transcoded, now I find that it has to be always included in the plex cloud. Please fix this on chromecast and ios because we are using the most compatible audio codec
Thank you
