Server Version#: 1.22.3.4392-d7c624def
Player Version#: ---------------------------
I running Multiple PMS on Ubuntu Server in my HomeNetwork. Before I was using a Single Server and Synology Nat and it working well.
Now i decide I want using LiveTV with Plex and order new Hardware. PMS#1 is running my Lib for Movies, Series and Shows … that’s fine and running well.
My PMS#2 is for LiveTV …so I change the external Port and open the Remote Access … this works for around 2 minutes, then I lost the Remote Access.
I check my Router about the Port forwarding and there is my Problem, I can’t forwarding 32400 to 2 local IP Addresses. Sure its unlogical to forward 1 Port to 2 IP addresses.
I live in Thailand and using a fiberglass Router with 1GB/1GB … my ports are like this:
PMS#1: 192.168.1.12:32400 100.1xx.xx.12:32400
PMS#2: 192.168.1.22:32400 100.1xx.xx.12:32500
Privat 192.168.1.22 : 32400 Public 100.1xx.xx.12:32500 > Internet
So I always lost my Remote Access about a Port Conflict within my Network. I can forwarding the Port 32500-32501 to 32400-32401 but … I can’t forwarding the same ports to 2 different IP Addresses!
I read some Postings by same request … I don’t know why they marked as solved because I the Port its hardcoding as I guess? The Modem/Router I can’t and won’t change because it working very well for me.
I trying to port forward the 32500-32501 port by ufw but not sure my way is the best solution?
P.S. ufw wasn’t a solution. PMS need a lot of ports. so I need a way to change them all
