I have just created a new music library, installed FlexAmp on my Android device and purchased the FlexPass.
I want to use it to control my Sonos devices. The connection with Sonos is established, I can see all Sonos devices. However, I can only select one device at a time for output. How can I control several devices at the same time?
As far as I know you cannot combine multiple Sonos speakers from within Plexamp.
Instead if you have grouped devices in the Sonos app first, then if you refresh the cast/players screen in Plexamp it should then show the group like ‘Bedroom Speaker +1’ that you can now select
Plexamp & Sonos should be a dream scenario, but in my experience is prone to connection bugs and sometimes just doesn’t work
Yes, combination of both apps works. Thank you.
I can even group speakers in Sonos after a cast has been started. Then I can also control the volume for each speaker separately there. I was hoping I could get rid of the annoying Sonos app.
