Multiple Guide Sources
Server Version#: 1.31.0.6654
Tuner Make/Model: HDHomeRun + Xteve
Guide/Lineup name: Plex
Using XMLTV?: No
Channel number/Name:
This is a question for the Plex team. Are there any plans to enable multiple guide sources so we can use Plex provided guide for one DVR device and xmltv for another?
I just wondered if there was a technical limitation blocking this, or if it could be added as a feature request?
You can already do this by setting up a second instance of Plex Media Server. If you’re wondering how to run two instances of PMS on one machine then use docker.
Unfortunately I can’t do that as running on Windows Server. It is an avenue I thought about but unable to change internal port of plex. I did try running an instance inside WSL2 but still had port map issues. I also didn’t really want to run 2 instances if there is another way to do it.
I’ve been playing around with Emby and you can use multiple guide sources there
I want this feature as well. Ive been scratching my head all day trying to figure this out. I have one tuner where I can use the Plex EPG fine, and another where I have to use an xTeVe dummy EPG. Not being able to use both without running two Plex servers would be nice
Yeah I’m in the same boat. I was running a second instance on my NAS but it couldn’t handle transcoding
@sa2000 would this be possible to implement?
