Multiple IR infrared remotes out of the box
Rasplex seems to be responding to my MCE remote as well as my Panasonic TV remote, which is very annoying. This is out of the box behaviour.
Where is the default configuration for lirc stored in Rasplex?
If you do not want it to use your Panasonic remote try disabling the CEC Adapter.
From the home screen hit left select 'Preferences', Hit left then select 'Change Preference for System', Hit down to highlight 'Input devices', Right to select 'Peripherals', Hit ok an make sure CEC Adapter is highlighted an hit ok then uncheck 'Enabled' then 'OK'.
Preferences
-Change Preferences for System
--Input Devices
---Peripherals
----CEC Adapter
Preferences
--Input Devices
---Peripherals
----CEC Adapter
RasPlex is responding to the remote via IR GPIO, not via CEC.
I found the solution.
My Panasonic remote was being detected as "Dream_Multimedia_URC-39930", which is part of the default lirc config in /etc/lirc/lircd.conf.rpi. I copied the file to /storage/.config/lircd.conf and removed that remote config from the file. Then I followed Step 5.1 of https://github.com/RasPlex/RasPlex/wiki/GPIO-IR to load the new config instead of the default.
Thank you!  I think that was my problem, thinking that HDMI-CEC was being used while I wasn't looking.  I have a Panasonic Plasma TV too.
Glad I could help out good sir - a year on too! cheers
