Please start a new thread, post in: https://forums.plex.tv/c/plex-players/gaming-consoles
Include the PMS version and Plex app version you have installed as well as PMS logs.
Hey thanks for that information, SLafferty!
I turned off the automatically adjust quality option to see if that might also help. It seems to, but that’s on my main system that the server runs from.
Will test it out on the bedroom TV that I have hooked to my laptop (got tired of the app for Vizio being hard to control with their remote) – in a bit. If it still happens, I’ll do what you suggested.
I really appreciate you taking the time to answer.
Have a great night!
Having issues with 1.18.1.1973 as well.
Running in FreeNAS jail. Using plexmediaserver-plexpass build
Console is being spammed with:
Nov 02, 2019 22:40:36.488 [0x81361c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.549 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.605 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.661 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.718 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.774 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.831 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.891 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:36.952 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2855 seconds)
Nov 02, 2019 22:40:37.009 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2856 seconds)
Nov 02, 2019 22:40:37.067 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2856 seconds)
Nov 02, 2019 22:40:37.122 [0x81321c000] Debug — EPG[cloud]: Next thing to start/end is at 2019-11-03 02:53:00 GMT (in -2856 seconds)
I have fairly high CPU usage while doing nothing. If I try and view live tv guide, my CPU usage goes to 100% and the guide never fully loads.
Looks to be the same issue form this thread in 2018 that was solved:
https://forums.plex.tv/t/bug-solved-epg-high-cpu-usage/225541
