Hi all! There’s a strange thing happening to my rasplex devices… I have a Plex Pass and multiple (headless) raspberry pi devices all accessing the same plex media server. Whenever I log in one rasplex device, the other becomes unreachable. I have to plug monitor back into it, logout from plex and log back in. Then the other becomes unreachable…
Any thoughts?
Have you fresh install every single RPI or did you clone sd card?
Use System Settings to change the name of each RPi, default is Rasplex, should be something unique for each RPi, change name in Preferences, again each name should be unique, restart all RPi’s once names are changed, sign out of each RPi and then sign in each RPi, completing manual registration, or better still using a PIN.
Should sort your issues out.
Regards
