Music Filter Request - Add "NOT" Function
In iTunes, I have a playlist that excludes anything I have played in the last 21 days, or have skipped in the last 10 days. This keeps my playlist randomizer fresh and replenishes my list after a period of time.
I want to be able to do the same thing in Plex. The current filter options let you do the opposite, but not this. Please add?
Thank you!
Already possible.
Unfortunately not:
This is a bug report and not a feature request, then.
I will file this as a bug.
Thank you for that. As I’m sure you can see, I first posted this in the bug report forum, but it was potentially explained away by another member. So I figured I’d try here. Thank you for doing that!
Is there any way down the road I can check in on progress? (I don’t like to hound people, I’m just very curious about the process and how things like this get managed.)
Sorry, no. The bug tracker is not public.
All good. I appreciate the info. Definitely excited to see that fixed! Thanks again!
@OttoKerner, I see there was a fix to the Track Last Skipped filter in the latest server update! Looking forward to trying that out! Thanks for pushing that through.
UPDATE: Seems to be working so far! Noticed a bit of an issue when using Plexamp, but don’t have definite data yet. I’ll report back if I can confirm.
Thanks again, Plex staff! You guys are awesome!
