I am a huge PLEX fan, but when it comes to music (library presentation) it has to improve.
It does work for popular music (with limitations as well), but It is just not good enough for Classical Music and it gets unusable when it comes to Box-Sets (i.e. Karajan Complete Recordings with 200+ CD’s).
To stick to the standard views like artists and/or albums with the available sort options just wont do it here anymore.
I totally hope on Plex to evolve here fast and innovative, so I have a suggestion here:
I know that the problem starts with the available tags already, since the standard id3 tags do not solve the issue in the first place.
How ever, MusicBrainz suggest a tagging scheme for classical music, and we should go from there.
Clustering/Grouping
The most important feature (useful for Movies as well) is to introduce an additional layer that enables a group of discs in the top view.
We could rely on the “GROUPING” tag that iTunes recently introduces (or the MovieSet fro Movies), but we could as well just have it manually maintained through the GUI (I select a couple of CD’s and “group” them - which should have the same effect than putting them in a folder in the CD view.) -
Movements, Artists, Album Artists, Composer
Just “add” the feature, that PLEX reads out these additional Tags (Movements introduced by iTunes as well - MOVEMENT, MOVEMENTNAME, MOVEMENTTOTAL), than we can use these Tags in custom views (next feature) -
Custom Views
Please “Add” some possibilities to have “custom views” with a music libarary, where one can select a view criteria on what is to include or exclude from the view, and than select data/tags to be used to “group” the view (possibly based on the additional Tags from (2.) -
Each “Group/Folder” should have its own “Custom View”
Now this is important:
It should be possible to maintain “Custom Views” for each Group/Folder, since this all is not about maintaining the standard beahviour but special cases like Box-Sets, etc.
Having all this would give us flexibility enough to handle more complex library scenarios
and would add a great boost to user-friendliness of large music libraries (like mine).
Thank you for your consideration.
