Music - multiple entries for same artist
Hi All,
Am running Version 1.26.0.5715 but don’t think this is an issue with the specific version.
For some reason, my Plex music library is separating the same artist into multiple areas… for example… I have 10 “Nick Cave” albums. All of the artists names are identical. All are spelled the exact same way - “Nick Cave” however, when I search for “Nick Cave” it asks me to choose a source.
I can fix this in a very non automated way by going into each album, editing the artist name, then selecting the first “Nick Cave” on the list for every album that’s doing this. It would take me forever to try and fix my entire library like this.
Why is that happening, and is there an easy fix for it?
Hope I described the issue properly…
  • Jon
The part I don’t get is when it asks you to choose a source. Can you screenshot that? I’ve never seen it ask that. Does it offer choices?
Here’s an example:
  • Jon
The only way I can get the “Choose Source” overlay is if I search for an artist or album that I have in different Music Libraries.
select_source
Is it possible you have two music Libraries both named “Music” (I don’t know if you can actually have identically named libraries of the same type) and if you do, are the both pointed at the same source files?
Maybe a manual scan and/or refresh metadata for the library would eliminate the multiple sources if you only have one library.
Just guessing… not a definite solution.
Yeah, I only have one source! Really weird. I’ll do a complete refresh to see if that helps.
Thanks!
  • Jon
Did you just recently convert your music library to use another metadata agent?
If so, trigger Refresh Metadata of the whole library, then go to bed. (because it can take a long time)
