Music not working
I’m not able to listen to my music thru the plex app, did something change?
Which type of Plex app, running on which type of hardware?
I have plex server running on windows server 2012 and I have remote access to my movies but music will not show up. Plex app on galaxy note 9.
Have you tried to access your music with a different Plex app (e.g. the web app)?
What does it mean when you say “it does not show up”?
Is the icon for music missing or is the screen empty after selecting ‘music’?
I have and it works thru the web. When I select music it says RETRY then that TIDAL shows up. It was working the last time I used it.
What other plex app would you suggest?
After Tidal shows up, do you see the library dropdown selector at the top?
It say TIDAL and a triangle pointing downwards. Tap on it.
I see it now, thank you so much.
