Music Playlist
Well, I can't get import of m3u playlists to work in any fashion whatsoever now. I can't get any matches on filenames and the artist / song information in the m3us are still reversed from what the plug-in expects.
I'm running Plex on Windows 8.1.
I am assuming the separator should be set to '\'. (The instructions are unclear on this - it says to put what the Plex server expects, but in the browser I see '/' used in paths so I've tried both, many times).
I am assuming the mapping field should be left blank in my case.
I have absolute paths in my m3u.
What am I doing wrong?
Hello,
I install the plug in on plex version 0.9.8.10 running on CentOS 6 and it working just fine, I use playlist manager on my PC with Win7 64bit and everything work perfect for now. My family use WP7 phones and it plays perfect the playlists in normal and random condition from home WiFi and from Mobile Data connections. Only problem is that we are in Bulgaria and we have a lot of Russian and Bulgarian songs which are on Cyrillic language, the play list editor uses some different encoding so the titles are in some bad script and nor recognizable. So we have to rename them in the MP3 tag for example with Winamp, than remove them from PMS, refresh music section, than return them with corrected tags on English alphabet  and again refresh music section to appear correct, otherwise everything work just fine.
Thanks for nice plugin, and I wish you all Happy New year.
Added an option to switch the Artist and Title in the import list.
Chrisjan,
i have noticed when adding tv shows to a playlist it saves only the title of the show eposide
like attached..
![post-117256-0-24861100-1388309529.jpg|690x353](upload://yRW7qFko50ZUwdIhieK2GLQi9fl.jpg)
would it be possible to be able to save as
for example
The big bang theory - The Big Bran Hypothesis
Hey,
very nice plugin - have been waiting for something like this for a long time!
Is there any possibility to control the playback on a client X via http?
I can control the playlist and its songs but I can not tell him to play a playlist xyz on client x.
So sorry for this noob post here. Been using plex for a little while and would love playlists. Use plex with my roku so overall pretty annoying since the GUI on the roku is really limited.
Having trouble getting this plug in installed. I download, drop into the plex > plex media server > resources > plug ins folder, tried to rename with the "-master" on the end, but not getting it to show up anywhere.
Any tips on what I'm missing? Thanks!
not resources
should go in the local appdata area not the program area
in the plugins folder
on windows it would be in
c:\users\xxxx\appdata\local\Plex Media Server\Plug-ins
not resources
Aha! Got it in , thanks! So, how do I add songs to playlists now? I configured plex to IP at 192.168.1.205, which is the plex comp. Should an option to add to a playlist appear? I created a new playlist and set all options, just not sure how to add the songs
^ as above. got both the plugins working now i think but im not sure how to add tracks to a playlist. can you add within PMS or do have to create a playlist out of software and import?
thanks in advance
From your Plex client:
Open the 'Music Playlist' channel
From the main Playlist menu select 'Playlist maintenance'
From the Playlist maintenance menu use 'Create new playlist' to create at least one playlist
From the Playlist maintenance menu use 'Add tracks to playlist'
    This allows you to browse through your Music selection
    When the selection is down to a single song and then you hit enter, you will get the option to add this song to any of the available playlists.
This procedure is very exhaustive.
There is also a standalone application available for managing the playlists.
This is a Windows application that requires .NET framework version 4.0.
It is available at: https://github.com/c...listManager.git
You only need the executable which is available at the path: .\PlexMusicPlaylists\bin\Debug
Thank you for that. Unfortunately, when I go to the playlist maintenance section it only states:
Create New Playlist
Set User current plex client
Ive done both and no dice so far.
Either way, I got standalone app and it works. Also works on roku device, but super slow so standalone works great, thanks!
Create New Playlist
That are the menu options that you get when there are no playlists yet. All other options should become available once you create at least on playlist.
Maybe you are using a plex client that has it's own caching mechanism  build in for for channel url's. I have seen something like that with my Panasonic TV.
Create New Playlist
yup this is exactly what i get. when i first clicked on playlist maintenance i did get the option to add to the playlist (it wouldnt let me browse my library though) but now that option has gone even though i have created playlists.
edit: after restarting PMS the options have returned under playlist maintenance but when i try to add tracks it just says channel unavailable.
Hi Christijan,
me and my live use this playlist very often, thanks for great job.
I have a question for the stand alone application Playlist editor, it works fine but searching tracks is not possible.
If I want to search exact track name which I want to add to playlist I use my WP7 or Windows Plex application. In this two Plex clients there is option to search by track name, but in WEB application and Playlist editor standalone applications it is not possible, there we can search only by Artist, Gener and so on.
Can you add search by track to Playlist editor stand alone application ?
Best regards.
First I would like to say great work on this plugin. I’ve been looking for this function in plex for awhile now. Currently my most used client is Plex Connect, and I am wondering if support will be added as of now the channel loads but won’t shuffle the playlists.
Chrisjan,
Just wanted to say thanks so much for this plugin, as well as (or especially, lol) the Windows Playlist manager. Very well done.
The one thing that would make the playlist managers just about perfect (for me, at least) would be the ability to select entire albums with one click and have all tracks added, without having to drill down to the individual track level.
Chrisjan,
This would be good for tv shows also..
Instedad of clicking on each ep
The ability to select by folder :)
Hi There,
thanks for all the hard work on this plugin.
I have installed, configured and created playlists. I can play them on a web browser and on my android phone.
I am running plex on a linux mint server. I can't get a playlist to play on a windows 7 computer running the plex client. I can see album art and playlists but it just sits there.
any ideas?
I think i have found the relevant log file and I have pasted it below. Any help with this problem would be appreciated.
Ian
014-02-18 19:22:51,242 (7f55a53bc740) :  INFO (core:336) - Starting framework core - Version: 2.3.16, Build: 2167b3f (Mon Jan 27 21:33:51 UTC 2014)
2014-02-18 19:22:51,242 (7f55a53bc740) :  DEBUG (core:348) - Using the elevated policy
2014-02-18 19:22:51,242 (7f55a53bc740) :  DEBUG (core:437) - Starting runtime component.
2014-02-18 19:22:51,244 (7f55a53bc740) :  DEBUG (core:437) - Starting caching component.
2014-02-18 19:22:51,245 (7f55a53bc740) :  DEBUG (core:437) - Starting data component.
2014-02-18 19:22:51,245 (7f55a53bc740) :  DEBUG (core:437) - Starting networking component.
2014-02-18 19:22:51,257 (7f55a53bc740) :  DEBUG (networking:318) - Loaded HTTP cookies
2014-02-18 19:22:51,273 (7f55a53bc740) :  DEBUG (networking:504) - Setting the default network timeout to 20.0
2014-02-18 19:22:51,274 (7f55a53bc740) :  DEBUG (core:437) - Starting localization component.
2014-02-18 19:22:51,274 (7f55a53bc740) :  INFO (localization:408) - Setting the default locale to en-us
2014-02-18 19:22:51,284 (7f55a53bc740) :  DEBUG (localization:426) - Loaded en strings
2014-02-18 19:22:51,292 (7f55a53bc740) :  DEBUG (core:437) - Starting messaging component.
2014-02-18 19:22:51,293 (7f55a53bc740) :  DEBUG (core:437) - Starting debugging component.
2014-02-18 19:22:51,293 (7f55a53bc740) :  DEBUG (core:437) - Starting services component.
2014-02-18 19:22:51,293 (7f55a53bc740) :  DEBUG (core:437) - Starting myplex component.
2014-02-18 19:22:51,293 (7f55a53bc740) :  DEBUG (core:437) - Starting notifications component.
2014-02-18 19:22:51,306 (7f558d7fa700) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.plugins.playlist'
2014-02-18 19:22:51,423 (7f55a53bc740) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.plugins.playlist in namespace 'metadata'
2014-02-18 19:22:51,435 (7f55a53bc740) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2014-02-18 19:22:51,478 (7f558d7fa700) :  DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2014-02-18 19:22:51,478 (7f55a53bc740) :  DEBUG (runtime:1108) - Created a thread named 'load_all_services'
2014-02-18 19:22:51,480 (7f55a53bc740) :  DEBUG (runtime:1108) - Created a thread named 'get_server_info'
2014-02-18 19:22:51,480 (7f558d7fa700) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2014-02-18 19:22:51,480 (7f55a53bc740) :  DEBUG (core:149) - Finished starting framework core
2014-02-18 19:22:51,481 (7f556ffff700) :  DEBUG (networking:172) - Requesting '
2014-02-18 19:22:51,482 (7f55a53bc740) :  DEBUG (core:547) - Loading plug-in code
2014-02-18 19:22:51,488 (7f556ffff700) :  DEBUG (core:525) - Machine identifier is 22542f7fe601ab41fc341b347e8266f235f048e2
2014-02-18 19:22:51,489 (7f556ffff700) :  DEBUG (core:526) - Server version is 0.9.9.1.357-b2fadd5
2014-02-18 19:22:52,081 (7f558d7fa700) :  DEBUG (services:362) - Loaded services
2014-02-18 19:22:52,220 (7f558cff9700) :  DEBUG (services:438) - No shared code to load
2014-02-18 19:22:52,632 (7f55a53bc740) :  DEBUG (core:553) - Finished loading plug-in code
2014-02-18 19:22:52,643 (7f55a53bc740) :  DEBUG (runtime:640) - Adding a prefix handler for 'Playlists' ('/music/playlists')
2014-02-18 19:22:52,645 (7f55a53bc740) :  INFO (datakit:24) - Resetting the dictionary
2014-02-18 19:22:52,656 (7f55a53bc740) :  INFO (datakit:93) - Loaded the dictionary file
2014-02-18 19:22:52,656 (7f55a53bc740) :  INFO (datakit:118) - No default dictionary file
2014-02-18 19:22:52,659 (7f55a53bc740) :  INFO (core:598) - Started plug-in
2014-02-18 19:22:52,659 (7f55a53bc740) :  DEBUG (socketinterface:160) - Starting socket server
2014-02-18 19:22:52,660 (7f55a53bc740) :  DEBUG (runtime:1108) - Created a thread named 'start'
2014-02-18 19:22:52,661 (7f55a53bc740) :  INFO (socketinterface:184) - Socket server started on port 44511
2014-02-18 19:22:52,661 (7f55a53bc740) :  INFO (pipeinterface:25) - Entering run loop
2014-02-18 19:22:52,661 (7f55a53bc740) :  DEBUG (runtime:717) - Handling request GET /:/prefixes
2014-02-18 19:22:52,663 (7f55a53bc740) :  DEBUG (runtime:814) - Found route matching /:/prefixes
2014-02-18 19:22:52,664 (7f55a53bc740) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 454 bytes
2014-02-18 19:22:52,757 (7f556ffff700) :  DEBUG (runtime:717) - Handling request GET /music/playlists
2014-02-18 19:22:52,772 (7f556ffff700) :  DEBUG (runtime:814) - Found route matching /music/playlists
2014-02-18 19:22:52,773 (7f556f7fe700) :  DEBUG (runtime:717) - Handling request GET /music/playlists
2014-02-18 19:22:52,776 (7f556f7fe700) :  DEBUG (runtime:814) - Found route matching /music/playlists
2014-02-18 19:22:52,782 (7f556ffff700) :  DEBUG (preferences:256) - Loaded preferences from DefaultPrefs.json
2014-02-18 19:22:52,783 (7f556ffff700) :  DEBUG (preferences:178) - Loaded the user preferences for com.plexapp.plugins.playlist
2014-02-18 19:22:52,784 (7f556ffff700) :  DEBUG (__init__:1314) - LoadGlobalPlaylistFile: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.playlist/DataItems/me_allPlaylists.xml
2014-02-18 19:22:52,842 (7f556f7fe700) :  DEBUG (__init__:1314) - LoadGlobalPlaylistFile: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.playlist/DataItems/me_allPlaylists.xml
2014-02-18 19:22:52,843 (7f556ffff700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,845 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,846 (7f556ffff700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,847 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,847 (7f556ffff700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,848 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,849 (7f556ffff700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,850 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,851 (7f556ffff700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,852 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,853 (7f556ffff700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,854 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,855 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:52,856 (7f556ffff700) :  DEBUG (base:123) - Checking if com.plexapp.plugins.playlist is broken
2014-02-18 19:22:52,857 (7f556f7fe700) :  DEBUG (base:123) - Checking if com.plexapp.plugins.playlist is broken
2014-02-18 19:22:52,865 (7f556ffff700) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjgKY29tLnBsZXhhcHAucGx1Z2lucy5wbGF5bGlzdHMxMAppZGVudGlmaWVycjAK'
2014-02-18 19:22:52,866 (7f556f7fe700) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjgKY29tLnBsZXhhcHAucGx1Z2lucy5wbGF5bGlzdHMxMAppZGVudGlmaWVycjAK'
2014-02-18 19:22:52,877 (7f556ffff700) :  DEBUG (runtime:106) - Sending packed state data (109 bytes)
2014-02-18 19:22:52,878 (7f556ffff700) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 2257 bytes
2014-02-18 19:22:52,882 (7f556f7fe700) :  DEBUG (runtime:106) - Sending packed state data (109 bytes)
2014-02-18 19:22:52,882 (7f556f7fe700) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 2257 bytes
2014-02-18 19:22:55,896 (7f556f7fe700) :  DEBUG (runtime:717) - Handling request GET /music/playlists/:/function/OpenPlaylistMenu?function_args=Y2VyZWFsMQoxCmRpY3QKMgpzNAowMDA0czExCnBsYXlsaXN0a2V5czIxClswMToyMDo0MV0gYXNzb3J0ZWQgMXM1CnRpdGxlcjAK
2014-02-18 19:22:55,923 (7f556f7fe700) :  DEBUG (runtime:814) - Found route matching /music/playlists/:/function/OpenPlaylistMenu
2014-02-18 19:22:55,923 (7f556f7fe700) :  DEBUG (runtime:143) - Calling function 'OpenPlaylistMenu'
2014-02-18 19:22:55,924 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:55,925 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:55,929 (7f556f7fe700) :  DEBUG (runtime:106) - Sending packed state data (109 bytes)
2014-02-18 19:22:55,929 (7f556f7fe700) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 1614 bytes
2014-02-18 19:22:55,946 (7f556f7fe700) :  DEBUG (runtime:717) - Handling request GET /music/playlists/:/function/OpenPlaylistMenu?function_args=Y2VyZWFsMQoxCmRpY3QKMgpzNAowMDA0czExCnBsYXlsaXN0a2V5czIxClswMToyMDo0MV0gYXNzb3J0ZWQgMXM1CnRpdGxlcjAK
2014-02-18 19:22:55,948 (7f556f7fe700) :  DEBUG (runtime:814) - Found route matching /music/playlists/:/function/OpenPlaylistMenu
2014-02-18 19:22:55,949 (7f556f7fe700) :  DEBUG (runtime:143) - Calling function 'OpenPlaylistMenu'
2014-02-18 19:22:55,949 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:55,950 (7f556f7fe700) :  WARNING (runtime:1056) - Generating a callback path for a function with no route:
2014-02-18 19:22:55,952 (7f556f7fe700) :  DEBUG (runtime:106) - Sending packed state data (109 bytes)
2014-02-18 19:22:55,952 (7f556f7fe700) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 1614 bytes
2014-02-18 19:22:57,636 (7f556f7fe700) :  DEBUG (runtime:717) - Handling request GET /music/playlists/:/function/PlaylistMenu?function_args=Y2VyZWFsMQoxCmRpY3QKMwpzNAowMDA0czExCnBsYXlsaXN0a2V5czQKcGxheXM0Cm1vZGVzMjEKWzAxOjIwOjQxXSBhc3NvcnRlZCAxczUKdGl0bGVyMAo_
2014-02-18 19:22:57,639 (7f556f7fe700) :  DEBUG (runtime:814) - Found route matching /music/playlists/:/function/PlaylistMenu
2014-02-18 19:22:57,639 (7f556f7fe700) :  DEBUG (runtime:143) - Calling function 'PlaylistMenu'
2014-02-18 19:22:57,640 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Token=prACNY1pzcZgqpZV9Nxp
2014-02-18 19:22:57,640 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Host=192.168.0.12:32400
2014-02-18 19:22:57,641 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Platform=Plex Home Theater
2014-02-18 19:22:57,641 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Model=Windows
2014-02-18 19:22:57,641 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Client-Capabilities=protocols=http-video,shoutcast;videoDecoders=h264{profile:high&resolution:1080&level:51};audioDecoders=mp3,aac,dts{bitrate:800000&channels:8},ac3{bitrate:800000&channels:8}
2014-02-18 19:22:57,642 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Client-Identifier=d82f6284-79a7-4b26-bd01-4507a5925c44
2014-02-18 19:22:57,642 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Connection=keep-alive
2014-02-18 19:22:57,642 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Accept=*/*
2014-02-18 19:22:57,643 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: User-Agent=Plex Firefox/2.0.0.11
2014-02-18 19:22:57,643 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Device=PC
2014-02-18 19:22:57,643 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Range=bytes=0-
2014-02-18 19:22:57,644 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Product=Plex Home Theater
2014-02-18 19:22:57,644 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Username=estaman
2014-02-18 19:22:57,644 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Device-Name=sini
2014-02-18 19:22:57,645 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Provides=player
2014-02-18 19:22:57,645 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Version=1.0.9.180-bde1e61d
2014-02-18 19:22:57,646 (7f556f7fe700) :  DEBUG (__init__:1348) - LoadSinglePlaylist: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.playlist/DataItems/me - 0004.xml
2014-02-18 19:22:57,679 (7f558cff9700) :  INFO (datakit:131) - Saved the dictionary file
2014-02-18 19:22:57,680 (7f556f7fe700) :  DEBUG (__init__:1366) - SaveSinglePlaylist: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.playlist/DataItems/me - 0004[Started].xml
2014-02-18 19:22:57,681 (7f556f7fe700) :  DEBUG (__init__:1378) - Total duration = 4841107
2014-02-18 19:22:57,682 (7f556f7fe700) :  WARNING (objectkit:199) - Media part has no streams - attempting to synthesize
2014-02-18 19:22:57,701 (7f556f7fe700) :  DEBUG (runtime:106) - Sending packed state data (109 bytes)
2014-02-18 19:22:57,701 (7f556f7fe700) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 15185 bytes
2014-02-18 19:22:57,728 (7f556f7fe700) :  DEBUG (runtime:717) - Handling request GET /music/playlists/:/function/PlaylistMenu?function_args=Y2VyZWFsMQoxCmRpY3QKMwpzNAowMDA0czExCnBsYXlsaXN0a2V5czQKcGxheXM0Cm1vZGVzMjEKWzAxOjIwOjQxXSBhc3NvcnRlZCAxczUKdGl0bGVyMAo_
2014-02-18 19:22:57,731 (7f556f7fe700) :  DEBUG (runtime:814) - Found route matching /music/playlists/:/function/PlaylistMenu
2014-02-18 19:22:57,731 (7f556f7fe700) :  DEBUG (runtime:143) - Calling function 'PlaylistMenu'
2014-02-18 19:22:57,732 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Token=prACNY1pzcZgqpZV9Nxp
2014-02-18 19:22:57,732 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Host=192.168.0.12:32400
2014-02-18 19:22:57,732 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Platform=Plex Home Theater
2014-02-18 19:22:57,733 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Model=Windows
2014-02-18 19:22:57,733 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Client-Capabilities=protocols=http-video,shoutcast;videoDecoders=h264{profile:high&resolution:1080&level:51};audioDecoders=mp3,aac,dts{bitrate:800000&channels:8},ac3{bitrate:800000&channels:8}
2014-02-18 19:22:57,733 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Client-Identifier=d82f6284-79a7-4b26-bd01-4507a5925c44
2014-02-18 19:22:57,734 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Connection=keep-alive
2014-02-18 19:22:57,734 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Accept=*/*
2014-02-18 19:22:57,734 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: User-Agent=Plex Firefox/2.0.0.11
2014-02-18 19:22:57,735 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Device=PC
2014-02-18 19:22:57,735 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: Range=bytes=0-
2014-02-18 19:22:57,735 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Container-Size=50
2014-02-18 19:22:57,736 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Product=Plex Home Theater
2014-02-18 19:22:57,736 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Container-Start=0
2014-02-18 19:22:57,737 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Username=
2014-02-18 19:22:57,737 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Device-Name=
2014-02-18 19:22:57,737 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Provides=player
2014-02-18 19:22:57,738 (7f556f7fe700) :  DEBUG (__init__:1679) - REQUEST.HEADER: X-Plex-Version=1.0.9.180-bde1e61d
2014-02-18 19:22:57,738 (7f556f7fe700) :  DEBUG (__init__:1348) - LoadSinglePlaylist: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.playlist/DataItems/me - 0004.xml
2014-02-18 19:22:57,799 (7f556f7fe700) :  DEBUG (__init__:1366) - SaveSinglePlaylist: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.playlist/DataItems/me - 0004[Started].xml
2014-02-18 19:22:57,799 (7f556f7fe700) :  DEBUG (__init__:1378) - Total duration = 4841107
2014-02-18 19:22:57,822 (7f556f7fe700) :  DEBUG (runtime:106) - Sending packed state data (109 bytes)
2014-02-18 19:22:57,823 (7f556f7fe700) :  DEBUG (runtime:915) - Response: [200] MediaContainer, 15185 bytes
