Music tagging in Plex is still (in best cases) weird
why does Plex insist on stupidity like this?
Sometimes people say that a picture tells more than a thousand words. I guess you might need to add a few extra words to put meaning to your screenshots… at lest the perceived stupidity isn’t obvious to me (watching while being on the road… so maybe I’m just missing something simple)
I agree with Tom, pictures are easy for you, but not necessarily for others. Although I finally figured it out – Plex has split this album into two, one with a single track (track 11), and the other with the rest. It’s most likely a “garbage in, garbage out” issue. I’ve seen this happen when the Album Artist tag isn’t populated, even if it’s the same as the Track Artist.
[HowTo] Configure Plex to use embedded metadata (music)
