Server Version#: 1.14.0.5470
Player Version#: 1.14.0.5470
Slippery When Wet by Bon Jovi keeps getting split into two albums with the same name, same artwork, etc…
The first album has tracks 1,2, 4, 6, 7, 8, 10, 11, 12
The second has tracks 3, 5, 9
All 12 files are in
.\Bon Jovi
.\Slippery When Wet
I’ve editted the metadata on each file to make sure the album names are all the same. I’ve also editted the album name in plex, and it’s the same name.
For the album to stay “together”, it is also necessary that each and every track has an identical ‘Album Artist’ meta tag.
This is particularly necessary if some tracks have a different ‘Track Artist’ set (for instance if there is a guest artist on that track).
An album “split” can also happen if some of the tracks have a ‘track number’ and/or a ‘disc number’ set in their meta tags and some tracks don’t have these tags.
Don’t forget the Plex Dance after editing metatags or renaming media files.
Ultimately I gave up and deleted the library… I will try re-importing it again tonight.
I was showing folder paths in the library… each of those are in terms of Artis -> Album -> music files
But Plex was taking all sorts of albums and mixing them around… Use Your Illusion vol 2 has about 12 songs on it, but Plex added in Glen Campbell, Jainey Frickey, and at one point Beethoven
I figured something went seriously wrong with the database for that library… none of my TV shows or movie libraries are that messed up.
Which kind of music library did you create? ‘Premium Music’ or ‘last.fm’?
Under
Settings - Server - Agents - Albums - last.fm
pull the line ‘Local Media Assets’ into the top most position
repeat the same under
Settings - Server - Agents - Albums - Plex Premium Music
Edit your music library
go to the ‘Advanced’ tab
tick the checkbox ‘Use embedded metatags’
go to the ‘Add Folders’ tab and make sure the path is exactly \\NASBOX2\Music
Do you have some folders, where there are just lots of files with no artist/album organisation? Folders with more than ~65 tracks in them?
Or multi-disc albums with more than 4 discs and no subfolder per disc, so that the number of tracks in one folder is again above of ~ 65 ?
Which purpose has the folder \\NASBOX2\Music\tmp ?
If you have been using this during the Plex Dance, then it made the Plex Dance ineffective.
Another idea:
Can you copy one of these folders over to your server machine and test them adding from this location?
Maybe it has to do with the UNC path.
additionally I have two PLEX servers running… the other one is the ReadyNAS is exhibiting the same characterstics (it’s the \NASBOX2 the server above is attempting to import.)
It’s mixing in some of the same Olivia Newton-John music, but with different albums.
Rhinestone Cowboy by Glen Campbell is still an Unknown Artist - Unknown Album even when scanned by the Plex app on the ReadyNAS where the files reside.
In this case though it stuck 2 songs by Conway Twitty on there instead of Olivia Newton-John
