Hej.
Har ett litet problem då jag håller på att rippa mina CD-skivor och för in dom i Plex. Rippar allt i wav för bästa kvalite men av någon konstig anledning hittar inte plex informationen om artister, låtar m.m utan lägger bara allt under en artist. Rippar jag däremot samma skiva i MP3 så fungerar allt som det borde. Någon som har en ide på hur man kan lösa problemet?
Filstruktur:
Musik
Artist
Album
01 - Låtnamn.wav
Rippar med iTunes för tillfället men kanske finns bättre program så man får med alla information?
Tack på förhand!
Sorry for responding in English:
If you are after the full CD quality in Plex, use flac instead of wav.
Flac files use a lossless compression and can be played by virtually every Plex client.
And they support embedded metadata, just like mp3 files.
Hmm okey. Problem is that i’ve already ripped like 200 cds so if it’s possible to make it work with wav that would be great.
Do you know any good flac-ripping program for mac os? Maybe I will continue with that from now on.
I don’t see this as a problem. There is plenty of free software around which allows you to convert your wav files into flac, quite easily.
Grab a few different programs and try it out, I’d say.
I have unfortunately no experience with Mac software, sorry.
If you are also using a lot of Apple devices as Plex clients, you may consider to use ALAC instead of flac.
AFAIK you can make alac files with iTunes too.
