My guide won’t pick up all channels from antenna
Server Version#: 1.21.2.3939
Tuner Make/Model: HD Tuner
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Just set up my new guide for the dvr update. Not all of the channels data is being collected. I have more channels than the guide collects, and I can’t select the channels because it doesn’t give me the option. How can I get these channels to be selected.
Assuming you’re over the air. When I had this problem, I entered a postal code or zip code that was closer to the stations that you’re missing in the guide. Picking a location that is even 5 miles closer can make a difference in what the provider will consider channels in range.
Looks like it worked to get a few more. I’m still missing a couple, but I have more than earlier to I’ll deal with it for now. Thank you for the help!!
