My server won't work on PC or Browser
Server Version#:
My server is currently running in a docker container on an Unraid Linux server. Earlier this afternoon, I tried to play a video on the linux flatpak app (on my personal pc) and got an Error code: s4032 (Manifest). The same thing happens when I go to app .plex .tv and when I enter the 192.###.#.##:32400 ip address.
At first I thought it was my app or firefox. And I still don’t know what is going on. The website says that my media server can’t remote connect on the local ip. But on app .plex .tv it says insecure connection. However, I know that isn’t true! The video thumbnails show up and the libraries are able to be browsed.
I have plex on my iphone. And even now, I am currently playing the same videos that refuse to play on browser on my mobile app. I can do this while on the local wifi or with mobile data. I can also stream with a 3rd party plex player, Girens. But the Official plex app, the plex website, and the local browser player all refuse to play any video and say there are remote access issues.
And to top it all off! Those same broken players can play audio files!!! I can play music and audiobooks without issues, just found that out. But videos refused to play. I’ve tried disabling the hardware acceleration. I’ve restarted the container. I’ve restarted the server. I’ve tried reclaiming the server. None of it helped and I am at my wits end!
Plex Media Server Logs_2026-09-25_19-29-11.zip (4.3 MB)
I’ve attached the debug server logs in the zip file below. Please. I am desperate for some kind of solution.
Try to force plex to reset/refresh your certificate.
Stop Plex, go to the Cache directory in your server folder, is there a certificate.p12 file in there? If so, rename it certificate.p12.old, and then start plex back up. It should download a new certificate named cert-v2.p12 .
Thanks for the tip, but it’s still not completely fixed. I can play the videos in the local ip browser (:32400) and I was able to reclaim the server after restart, but the remote access is still saying indirect.
Can you screenshot the remote access page and share it, only blur out the public ip. The private ip (192.x) is safe to share/not block out, it’s a local ip on your network.
Did you manually set a port in plex, and create the forwarding rule on your router for the port? If so, share the port forwarding screenshot from your router/app. Again, only block out your public ip.
Lots of folks can get this info from your logs, but I haven’t dug into interpreting them yet, so asking for the above.
Also, in the plex network settings make sure it’s set to ipv4 only.
I also usually suggest folks disable plex relay in the network settings to avoid falling back to that, especially when setting things up.
