MyPlex and rasplex (plex server over wan?)
In another post someone said he had to log-in to myplex on his rasplex. I installed 0.37 but I didn't get an option to log into myplex. After first boot I got a language question (said to put it on English but it switched to my local language anyway?).
After this I got the network question (which network to use). And then I got the main menu.
I then continued to manually put in my server WAN ip adres. This didn't work (or atleast nothing happend), a reboot didn't work.
So is rasplex working with myplex aka WAN streaming or not? Did my rasplex bugout and I therefor could not login to myplex or is it not avialable at all?
For the record. My ipad/iphone is streaming fine over the wan so it's not a routing issue.
nothing in Preferences -> System -> MyPlex?
manually entering the IP will not work unless you plan to disable all your server side security. (aka, the myPlex login also grants the required security creds)
zomfg. I so missed that. searched trough some things but im not sure how I could have missed that.
Maybe an idea to jump to that menu on first boot.
