Rasplex no connection to Server
Hello,
I did just a clean installation of rasplex 0.2.2.
I have a Plex Media Server running in Version 0.9.7.28 on a Synology DS412+ running DSM 4.3-3776-1.
On my iPad I have the Plex App, what is working fine.
I can play videos on my iPad and also from the iPad to the rasplex, works great.
But I cannot browse though any of the videos on my rasplex, there is just nothing.
I didn't need to make any settings in my iPad Plex App and it works.
On the rasplex I added my NAS-Server IP address, but that doesn't fix the problem.
I hope someone could please help me!
315
Please describe your problem I’m more detail. It seems RasPlex has detected your sections and they should be visible.
Please check your network to allow multicast to avoid the need of entering your PMS-IP manually.
(It’s possible to login to myPlex as well to get a semi-automated setup working)
Please describe your problem I'm more detail. It seems RasPlex has detected your sections and they should be visible.
(It's possible to login to myPlex as well to get a semi-automated setup working)
What do you mean with more details. What specific?
The sections are detected on the iPad, but aren't shown on the Rasplex.
Multicast is allowed.
When I don't enter the IP manually, nothing changes...
What else can I try?
Are you using the confluence skin? (This skin does not have Plex support)
