Naming and Organizing - poster
Does Plex even use the poster to get the right info ?
Thank you
What exactly do you mean?
If you place an image using the correct naming schema alongside your movie file, Plex should find that when you add the movie. If it’s used will depend on your library configuration and what agent you’re using for your library.
No, Plex won’t look at the poster image and read the name of the director or the top-billed cast from it.
Instead, it does look up the movie at online metadata databases. Which is why it is important to name the file correctly. Category : Your Media | Plex Support
Thank you so much
