Hi!
I recently noticed that some of my movies doesn’t play the external srt subtitles. I made sure that the srt file and the movie file are in a separate folder and it had the same exact name of the movie file. I initially though it was version 1.0 so I downgraded to 0.9.17 and 0.9.16.x which had the same issue.
However, I am sure that I never had this issue before with the older version. I just can’t remember when or what version it started.
So I found out how to fix it but it caused another annoying issue.
I found out that if you name your movies with (2016) or (2015) or (2014) etc … the external subtitle won’t play.
Example:
Folder name: Warcraft (2016)
Inside this folder I have Warcraft (2016).mkv and an srt file Warcraft (2016).srt - notice there is a space between warcraft and (2016).
If I simply name it Warcraft.mkv and Warcraft.srt it works! However, the new issue with remove the year is that Plex doesn’t know what that movie is and just giving a generic thumbnail (its not getting it from the online movie database). Or sometimes it picks up the really OLD movies instead of the latest one.
Is there a way to make the external subtitles work without removing the year in the naming?
Thanks!
EDIT: I have about 100+ movies in my database and since I never really had this issue before … it is a big hassle to rename EVERYTHING removing the year
