NAS Synology DS118
Hello guys,
I am about to buy NAS DS118 and I was wondering if this would be right direction.
I would like to stream 4k HDR movies to my LG OLED C8 - all direct play.
Is the plex media server for this kind of NAS still in Beta? where can I find the download link please?
thanks a lot
Also, give this a read:
I’ve got a couple of 4k LG sets and they both work very well with 4k content from PMS, so long as you do everything you can to avoid transcoding and get the fastest network connection between your TV and PMS host. For me, that means:
  • connect the TVs to the network using 5GHz wifi rather than the 100mb/s wired network (this may or not be your best option, depending on the strength of your wifi signal and how many neighbours interfere)
  • avoid TrueHD soundtracks, they don’t automatically fallback to ac3 and can’t be passed to your sound system over ARC and will trigger a transcode
  • DTS-HD MA or DTS are good audio options
  • don’t use bitmap subtitles like PGS, stick with SRT. The LG sets can display text subtitles without transcoding
  • ymmv, but I tend to choose reencoded movies over remuxes, as the bitrate is lower
