Need help Installing Plexpy on Windows 10
Tried installing Plexpy on windows 10 and it has no default program for .py files. What do I have to do to get it to run? I attempted to make it open with IE and that of course didn’t work. Please any assistance is appreciated!
Sorry if this isn’t in the right category first timer posting here.
Thanks,
Dylan
Do you have Python 2.7 installed first?
That will make .py files run.
I just set this up on my Win-10 server 30 mins ago.
I have not actually installed Python, I was hoping there would be some sort of pre-installed option. I’ll try that and let you know if it works. Thanks a ton!
There are instructions on the plexpy site, I believe.
I did install Python 2.7 but I’m not sure how to run the .py through it, i opened the gui and attempted to open the script and run the module and got an error. Anything I’m doing wrong.
also I did try to follow the instructions on the github but they basically say double click plexpy.py and it works lol.
Again, thanks for the quick responses you guys are great.
Aha! I got it, I didn’t change the program back to python for the .py files. Thanks
