plexconnect.py won't load
After a windows update the plexconnect.py file does not load. it opens the command prompt for 2 seconds then closes.
16:48:28 PlexConnect: started: 16:48:28
16:48:28 PlexConnect: Version: 0.5-dev-110616
16:48:28 PlexConnect: Python: 2.7.12 (v2.7.12:d33e0cf91556, Jun 27 2016, 15:19:22) [MSC v.1500 32 bit (Intel)]
16:48:28 PlexConnect: Host OS: win32
16:48:28 PlexConnect: PILBackgrounds: Is PIL installed? False
16:48:28 PlexConnect: IP_self: 192.168.0.14
16:48:28 DNSServer: started: 16:48:28
16:48:28 DNSServer: ***
16:48:28 DNSServer: DNSServer: Serving DNS on 192.168.0.14 port 53.
16:48:28 WebServer: started: 16:48:28
16:48:28 WebServer: ***
16:48:28 WebServer: WebServer: Serving HTTP on 192.168.0.14 port 80.
16:48:29 WebServer: started: 16:48:29
16:48:29 WebServer: ***
16:48:29 WebServer: WebServer: Serving HTTPS on 192.168.0.14 port 443.
Any ideas?
Meant to add this is on windows 10
Latest version of plex and plex connect
Thanks for the help!
