Under plex web general I found this : Version 4.47.1 not sure what it refers to
Hi! I would like to organize my movies and clips so that when I view my server on my windows PC or on my FIre box they are not in a total jumble.
I notice that they display differently on the fire box and the windows PC - the PC is less of a jumble. I would like to fix this for both platforms.
Most of the files are organized correctly by plex but there are a few that are incorrect and I see no way to correct it. Meaning: a movie is filed as a music video. How do I file it as a movie?
3, I found this page and I would like to organize them like this but it seems to be a back end thing and there are no instructions on how to access that. How do I access this?
First of all how are your files currently organized? Are you following the correct Plex format?
Drive/Movies/Movie Title (Movie Year)/Movie Title (Movie Year).mkv
Drive/TV Shows/TV Show Title (TV Show Year)/Season 1/TV Show Title S01E01.mkv
Drive/TV Shows/TV Show Title (TV Show Year)/Season 2/TV Show Title S01E02.mkv
etc…
As I stated, I uploaded them. I have no idea how to organize them that way without instructions on how to access this back end coded data. I am using the gui.
What you are referring to as ‘back end’ is just basic file organization.
Do you know how to create folders and how to move and rename files in Windows?
All I did was upload my movies - which currently exist in folders on windows. So yes I understand that. I do have them organized in a special Plex folder, not named movies Are you saying that I have to have the folder specifically named /Movies ? Also why does the movie need to be listed twice? lastly parentheses are not recognized in windows naming convention so please explain…
What is .mkv?
so currently its
drive/Plex/movies/Red.wmv
drive/Plex/tv shows/diary.wmv
drive/Plex/music/nin.wmv
FYI if you look at the link I included, that looks like basic linux type coding. I see from your comments that it was not intended to read that way and was simply an attempt to indicate windows file structure.
Thank you Dan. So each item needs to be in a separate folder of it’s own in windows? That is what I don’t understand. In other words I will have to create a folder for each file?
I get the folders for Tv shows and albums. It seems illogical and redundant for each individual movie. It is what it is, however. Thank you for the explanation.
I am not sure how to set up separate libraries in Plex, it seems that plex read all the folders and added the files, which is why it’s jumbled. .I would love to clear that up by pointing the library to the appropriate folder!
You may not feel that Plex is intuitive but there are support articles for every situation imaginable.
How did you set up the library you have?
Did you select drive/Plex as the base folder?
Do the same thing but go one folder farther. One for each, Movies, TV Shows and Music.
There is a reason for this. Plex treats each media type differently. Getting info for each from different sources.
Movies have their own folders because in a lot of cases there are more than one file per movie. There is the video, subtitles, cover art and other graphics.
Your PC filing system is the same as a filing cabinet. You wouldn’t (or shouldn’t) throw the info for every movie you own into one file folder then expect to find the info for one movie easily.
Thank you Dan. This brings up a separate question - I noticed that the subtitles are not included in the files. I see that mkv does include them. I use VLC which may not be the best tool for this process as it has issues with mkv files. Can you recommend another program for converting my DVDs?
That is the ‘Duplicate’ indicator.
Plex has recognized more than one file as being the same movie.
Whether that is correct, only you can judge.
Call up the Plex media info of this item, then look at the path and file names at the top.
Sticking to the recommended naming schema helps to avoid mismatches like this.
