Need help with choosing a CPU
I’m looking at building a Plex machine. I do plan on running other things on it but the CPU for those isn’t as important. I have every part from ram hard drives including a Quadro A2000 GPU. I’m looking at either an Intel i7 13700k or an R9 7900x. At most I’d be doing 3 4k transcodes. I do plan on running windows on the machine. Just what are your guys thoughts on this?
Server Version#:
Either is overkill for 3 x 4K transcodes, and they seem pretty equal performance wise. With the i7 you don’t need the Quadro. You can use the integrated Quick Sync graphics.
Using Hardware Accelerated Streaming
What kind of CPU do I need for my Server?
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-13700K&id=5060
https://www.cpubenchmark.net/cpu.php?cpu=AMD+Ryzen+9+7900X&id=5027
