After looking at the community tuner list I saw that the EyeTV Netstream 4stat worked for others.
Mine arrived today, I set it up and Plex saw it on the network perfectly fine.
I selected: 28.2E, None, and KU-Linear (Universal) as the options.
Scanned channels and it found like 788 channels.
Put in my post code, and selected FreeSat South Satellite also tried Sky HD one.
It downloads the guide and all looks well. When I click play I get: Could not tune channel. Please check your tuner or antenna. Tried many channels and retried many times.
Also it says: 788 channels— 89 enabled
Does anyone have any idea where I went wrong?
If I use the EyeTV app and use 28.2 Astra E it plays everything perfectly fine without issue.
Hi, you have to connect at least the first 3 Sat inputs with your Multiplexer (The first Plex Stream goes to input 3, the second stream/recording to input 2, the third stream/recording to input 4 and the fourth stream/recording to input 1). After that you go in the Netstream App on your mobile device to settings -> LNB-Settings -> and then you choose the number of connected cables.
it could work, but the Netstream app will show up “no signal” because the app thinks that you have connected 1 and 2. The best way is for you to use a multiplexer that you can connect all four inputs from the the multiplexer to the Netstream4Sat. https://en.wikipedia.org/wiki/Multiplexer
The two cables from your sat dish goes to the Multiplexer input and then from there four cables to the Netstream4Sat
